I am using Acad civil 2009. I would like to be able to switch between layouts using tabs. currently I have to use the Quick view layouts button and it is not as handy as the tabs. I have tried right clicking on the MODEL and PAPER buttons in the bottom right and this produces nothing.
On the status bar, right-click the Model or layout button. Click Display Layout and Model Tabs
When I right click on the MODEL button nothing happens i.e. no menus pop up or anything. When I left click on the MODEL button it changes to the PAPER button. Right clicking and left clicking on this PAPER button gives the same results.
in your command line type in CUI (customize user interface)
a dialog box will appear where you can customize things like showing the model/paperspace tabs. Just make sure where it says model/layout tabs, it's turned on.
if you need more in depth, the help menu has an explanation of customize user interface.
Options, Display, Layout elements, Display Layout and Model Tabs.
