chris l Posted April 19, 2010 Posted April 19, 2010 Hey guys having a bit of trouble here. Im currently trying to set out some detail drawings i have done for uni. I would like to have a sectional detail and also a couple of larger details to show some close ups and some more detail. I was wondering if it is possible to have say the section at 1:15 and the larger details at 1:5 and have them on the same layout sheet. Currently i can only work out how to set the scale of the layout and cant work out how to set the scales of the other details. This means that every time i copy another detail in it goes to the same scale as the layout sheet. I hope this makes sense and someone can help me. Thanks in advance chris Quote
ReMark Posted April 19, 2010 Posted April 19, 2010 Scales are assigned to individual viewports in your layout. Therefore it is entirely possible to have ten different viewports, each with a different scale, in a layout that will ultimately be plotted at a scale of 1:1. I typically select my scales from the Viewport toolbar. Scales can also be assigned to a viewport using the Zoom > Scale > nXP option. Quote
ica_cici Posted April 19, 2010 Posted April 19, 2010 Do as Remark said, "Zoom > Scale > nXP option" but you can also use solprof comand for the solid object, and insert by the scale you want. Quote
