airrace Posted June 3, 2010 Posted June 3, 2010 LT2011 Student Version. No problems for a month... Today my drawing when open informs me that it is either in use, or read only, neither of which is true. I am also now, getting an error message when trying to save changes in any drawing..."You do not have permission to save to this location. Contact your administrator to obtain permission" Any help from you angels? Steve Quote
ReMark Posted June 4, 2010 Posted June 4, 2010 It sounds like a "permissions" issue. You should be running your computer as "Administrator". Quote
bonehead411 Posted June 4, 2010 Posted June 4, 2010 Are you at school / college when you get these messages? Sounds like your trying to save to a restricted area on the network. Make sure you're saving in the folder set up for you on the students area of the network, or to a USB memory stick. Quote
Tankman Posted June 4, 2010 Posted June 4, 2010 Read only, doesn't sound like a problem. Can you open the read only *.dwg file? If yes, you would need to save with a different name. Or, as bonehead411 said, a USB memory stick. We used to use the floppy at school to take our work home every day. Sometimes, I would misplace my GF's disk 'cause she worked so neatly made me look like a dummy! Quote
MikeScott Posted June 4, 2010 Posted June 4, 2010 We used to use the floppy at school to take our work home every day. My old computer teacher used to have the lab set-up with magnetized heads on the disk drives.. to prevent students from loading programs from floppy disk. Nasty old scenario that instantly erased your data. Quote
airrace Posted June 4, 2010 Author Posted June 4, 2010 It sounds like a "permissions" issue. You should be running your computer as "Administrator". Mark, that fixed it...Many thanks, Steve Quote
ReMark Posted June 4, 2010 Posted June 4, 2010 Mark, that fixed it...Many thanks, Steve Really? Hot diggity dog! That's the ninth correct answer this year. I am on a roll man. Just having some with you there. I'm glad to hear it worked for you. Thanks for updating us. Quote
