This works good but, I would like to have the 2 objects rotate clockwise..not Counter clockwise
(defun c:90R( / e f p a b c i)
(vl-load-com)
(setvar "cmdecho" 1)
(setq e (vlax-ename->vla-object (car (entsel "\nSelect object: "))))
(setq f (vlax-ename->vla-object (car (entsel "\nSelect object: "))))
(setq p (getpoint "\nSelect rotation point: "))
(setq a 1 ; Number of revolutions
b 1 ; Degrees per increment (must be a factor of 90)
c 01 ; Delay between incremental rotation
i 0) ;
(if (= 0 (rem (setq d (/ 90 b)) -1))
(while (
(repeat d
(vla-rotate e (vlax-3d-point p) (* (/ pi 180.0) b))
(vla-rotate f (vlax-3d-point p) (* (/ pi 180.0) b))
(vl-cmdf "delay" c "regen")
(setq i (1+ i))
You will get a better and faster response if you post in the correct area of the forum.
Question moved to the Lisp section.
Just change your angle to a negative number. Hell, make 180. -180.
djw
Try to use # button to paste your code to be readable as a code
LIKE THIS
Hi
Here it goes,
(vl-load-com)
(setvar "angdir" 1)
i 0) ;
(while (< i a)
(repeat d
(setq i (1+ i))
(setvar "angdir" 0)
Regards
Tharwat
Check Red code
Why did you select object 2 times (e and f)
 (vl-load-com)
 [color=red](defun *error* (msg)[/color]
[color=red]   (and uFlag (vla-EndUndoMark doc))[/color]
[color=red]   (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")[/color]
[color=red]       (princ (strcat "\n** Error: " msg " **")))[/color]
[color=red]   (princ)[/color]
[color=red])[/color]
[color=red](setq OldCMDEcho (getvar "cmdecho") ; Save System Variable[/color]
         i 0) ;
   (while (< i a)
     (repeat d
    (setq i (1+ i))
      [color=red](setvar "cmdecho" OldCMDEcho) ; restore System Variable[/color]
[color=#ff0000]      (princ)[/color]
Why this?
[color=red](and uFlag (vla-EndUndoMark doc))[/color]
Or was it just a copy/paste job from my code? :glare:
Seems like that but there was a code line I didnt paste.
(setq uFlag (vla-EndUndoMark doc))
Any way welcome back
Thought I was post’n in the correct place? AutoCAD Forums> AutoCAD Customization> AutoLISP, Visual LISP & DCL
Anyhow think U-all for the reply’s.. Alanjt (–180) seems to work,
just try’n to learn, could you translate to plane English?
“(vla-rotate e” =Selected object
e
“(vlax-3d-point p)”=get 3D x y z of Selected object
e, what doses the “p” do?
“(* (/ pi 180.0) b))”= ???? 180 = Counter clockwise
-180 clockwise ??????
ya I know just try’n to learn..
Asos2000, object 2? Rotating two objects @ the same time..
thanks again…
Read the help file on vlax-3D-point, it creates a variant ( 3-element array of doubles ) from the point 'p'.
