Insener07 Posted July 20, 2010 Posted July 20, 2010 Hi! Is it possible to determine how it shows the bottom view in ACAD? For example:bottom view along y-direction or along x-direction. Thanks! Quote
lpseifert Posted July 20, 2010 Posted July 20, 2010 I don't know if this is available in LT... View > 3d Views > Bottom Quote
Patrick Hughes Posted July 20, 2010 Posted July 20, 2010 I don't know if this is available in LT... View > 3d Views > Bottom If this does not work look up the VPOINT command in help. As an alternative you can manipulate the UCS then issue the PLAN command. Quote
