zamyang Posted May 14, 2009 Posted May 14, 2009 Hi everybody. I'm new to this forum and I would really appreciate if you could help me. I'm going nuts trying to create a road along a hilly terrain! I'm working on a project that involves making a walkway along the road. The presentation date is nearing and i still don't have a proper rendered site plan! Please help! site plan with road.dwg Quote
shift1313 Posted May 14, 2009 Posted May 14, 2009 welcome aboard. your drawing doesnt have any elevation to it. Everything has the same Z coordinate. Quote
zamyang Posted May 15, 2009 Author Posted May 15, 2009 Thanks Shift1313. Yup, its a 2d site plan of 5 meter each contour interval. I've create a 3d view out of it! I managed to create the contour but its like in steps coz i extruded each contour line....and now I'm stuck!! How am I supposed to go about it? Quote
Zorg Posted May 15, 2009 Posted May 15, 2009 use 'EXTRUDE' on objects(probably as good idea to have used polylines), set your view to isometic or have several by selecting 'view' from the menu. Z Quote
shift1313 Posted May 15, 2009 Posted May 15, 2009 If you have a path you want your best bet is draw guides for each side and SWEEP or LOFT. Do you have a 3d file with a path you want to use? Quote
bobcampbellim Posted August 29, 2010 Posted August 29, 2010 Thanks Shift1313. Yup, its a 2d site plan of 5 meter each contour interval. I've create a 3d view out of it! I managed to create the contour but its like in steps coz i extruded each contour line....and now I'm stuck!! How am I supposed to go about it? You should actually click each line and change the elevation of the line. You should find "elevation" in the properties section. if you extrude it will turn the joined polyline into a shape Quote
