Hello Everyone
I have a question about the Vlide settings. I had it (at one time) where when vlide encountered an error it would tell me what the error was. I must have switched somthing and now it doesn't tell me what the error was. It just quits evaluating.
Does anyone know what setting I need to be looking at?
Thanks in advance
hippe013
Sounds like the *error* handler has been overridden.
Type:
(setq *error* nil)
at the command line and see if the problem persists.
Thank you! Thank you! Thank you!
Thats exactly what it was!
I'm glad :)
However it is worrying that it was the cause, as this means you are running a badly written program in which the error handler has been redefined and not reset or localised.
Lee
You are right... and I believe I know where the culprit is... I will have to double check the function collection that I use.
Thanks for the heads up
