Counting text from point in the string
I want to count text but want to start it from a dash in the text. Only thing consistant in the test is the dash.
I know strlen to count but do I convert to a list then use member?
examples of string
Cooler - ...
Freezer - ...
Freezer Refrigeration - ...
If you're trying to count the number of characters after a - in a string
here's one way... if a - isn't in the string you'll get an error
_4$ (- (strlen "Cooler-123")(vl-string-position (ascii "-") "Cooler-123" 0 ) 1)
3
Edited by lpseifert
(defun foo (s)
 (vl-string-left-trim
   (substr s
           (+ 2
              (cond ((vl-string-search "-" s))
                    (-1)
(foo "alan - thompson") -> "thompson"
(foo "alan") -> "alan"
Not dissimilar to Alans...
(defun foo ( s )
 (vl-string-left-trim " "
   (vl-list->string
     ( (lambda ( l ) (cond ( (cdr (member 45 l)) ) ( l ))) (vl-string->list s) )
