I am copying Thai text and pasting it into MTEXT and it works great. I paste it into a TEXT field and it comes out all ??????
What is the reason for this? Like one command sees the font and the other does not. :?
Maybe the field has a character limit and it has been exceeded?
Not sure I understand.
If I take a 4-5 letter word i English and translate it... comes up, say the same amount of Thai characters... I wouldnt think that would be a character limit.
make sure you are using the same text style in both MTEXT & DTEXT objects, with no font override in the MTEXT.
Can you Explode one of the Mtext you have done to see if it changes to ?????
Yes, I have... it turns to ?????????
Going to have to look into this... not sure how to verify this.
This is worth trying,
I tried it with Persian text and initially had same issue ( text turning into ????), but I had a look in the Mtext Properties box and in content noticed the font is Arial, so went to TextStyle and changed my font to Arial and everything is OK now
