RevolverSly Posted October 21, 2010 Posted October 21, 2010 Hello. Well, there is the situation: I've installed a thrid party menu utilities called "Arqcom's CivilCad 2008" -http://www.arqcom.com.mx/civilcad.html- which allow me to use tools for topographic matters -contour lines,etc-. And then, for some reason, the Point Style dialog is gone, when I write DDPTYPE on the command, show something like: error: LOAD failed: "DDPTYPE.FAS" So, I repaired the AutoCad, and then the Point Style appear again, but when load the menu utilities, the same error again. Some help to fix that please, certainly I need change the points to show it in the plotted drawings. Thanks in advance. Quote
RevolverSly Posted October 21, 2010 Author Posted October 21, 2010 @RenderMan No, ._ddptype doesn't work, the same error: LOAD failed: "DDPTYPE.FAS" There's some way to restore the "ddptype.fas" file to AutoCad?, maybe if I locate the file in other computer and then copy to mine?. Quote
