Can I plot data from EXCEL in AutoCAD?
I'm curious if it is possible to plot points (or a PLine, or a mesh) in AutoCAD from a table of values in EXCEL (columns of x,y,z coordinates).
Thanks
Yes you can, a few years back i came across a webpage that showed a way of formatting an excel sheet for data entry, then a simple cut and paste onto the command line enabled autocad to insert points to the correct x,y & z locations.
I will do a google search and see if i can find it. CadTutor knows the process, maybe he can elaborate it with finer detail.
G
Thanks a lot G, that was easier than I'd hoped even.
The Concatenate() command in excel, and the concept of pasteing text into the CAD command line are both beautiful.
Glad to be able to help you out.
I have not had a use for it, but it would be handy if you had
say gps points or surveying data.
It would be great if it it could be tied into a lisp routine to create a
mesh for terrain modeling.
Welcome to the forum, if no one has said already.
G
  • 7 years later...
Well, seeing as this thread is from 2003, what did you expect. Try a new search.
  • 1 year later...
khalid:
I'm not sure why you decided to post your question inside an unrelated thread but I would suggest that in the future you start a new one. Thank you.
