Can someone please help. I'd like a program to auto generate blocks for me based on the attached file. The generic block is my template and the othere is what would be a finished product. It would be great if I could fill in a spead sheet and end up with a block.
Thanx in advance for any help.Request for help.dwg
Do you really need it to be a block ? its pretty easy to do a 2 column table from excel then number of rows does not matter if you use a block then number of rows is a problem as you will need a block1 block2 block3 - block24 and so on. If your happy to do every block then search for "attributes" lots of stuff about updating from excel.
I'm not sure I follow you. I want the blocks to be just as they are in the dwg. Complete with layer and attributes. They will end up being write blocked out to a library sorted by Manufactorer/Model# so they can be used in other drawing without having to look up the information again. I tried making it a while back but as soon as I started getting the dotted pairs figured out I got swamped with projects and just don't have the time to figure it out. I've not done much programming and feel like I've forgotten most of what I knew.
Edited by Vidiot
