Hi all.
I just installed Autocad Map3D 2012.
I just realized that when I select multiple nodes on a polyline (by holding shift and selecting nodes), and then zoom the drawing, all the nodes gets deselected :unsure:
Anybody else had this problem? It's really annoying because i'm supposed to move chunks of a large and complex polyline in several segments using snappoints.
Thanks in advance:)
I suppose that you are performing those zoom operations by using ZOOM command - try to use mouse wheel alternative instead.
Regards,
Mircea
Regards,
Mircea
Thank you for fast reply, but no, I use the mouse wheel kind of zoom.
In this case, try to disable REGENAUTO to see if helps.
Regards,
Mircea
I think it might be a bug. I tried a couple of different things and it seems this only happens to files from earlier versions of AutoCAD.
