Anyone know a program that can accept point clouds (which will be millions of points) from a 3D laser? Then we would like to create a solid model of the structures and piping.
Thanks for the help
There is a plug-in for AutoCAD that might work. Check this out...http://autodesk.blogs.com/between_the_lines/2010/07/convert-point-clouds-into-real-geometry-in-autocad-2011.html
Kubit have PointPlant that can do automatic recognition of pipes and fittings
we have Poly-works but he is looking for something that will accept the point cloud and do the center of pipes and sharp edges of I-beams
