A few months ago after much hair pulling and some advice here and there I came up with this nice snippet which changes the TextOverride for a dimension that is the (entlast).
(vlax-put-property (vlax-ename->vla-Object (handent (cdr (assoc 5 (entget (entlast))))))
   "TextOverride" "<>\\PFRAME OPENING")
Today I was asked if we could rotate the dimension 90° counterclockwise so I tried this:
   "Rotation" (dtr -90.0))
and bingo, it worked like Lee-Mac or Fixo had written it themselves for me. The request also came to adjust the Text vert pos to "Above" instead of "Centered". So I thought cool, I'll just try it like this:
   "Textposvert" "Above")
but no such luck. I end up with:
Error: ActiveX Server returned the error: unknown name: Textposvert
I tried all kinds of variations for Textposvert, (Text Pos Vert, posvert, pervert....) anything to see what might work. But so far nothing is working. I was hoping this would be just as straight forward as the first solution.
This is for my totally automated process...no user input is allowed, only code for a solution. Any suggestions would be appreciated.
Bill,
Aside from your question, have a think about what this expression is doing:
You receive the error because a Dimension object does not have the property 'textposvert'. If you are planning on just guessing the names of properties that VLA-Objects possess, then prepare for a long time spent pulling your hair out...
Instead, consider using the vlax-dump-object function in conjunction with the ActiveX & VBA Reference as part of the Visual LISP IDE Help Docs.
After a quick check with the above function, I can see that the property you require is the TextGap property. However, note that this will be applied as a Dimension Style Override!
Did you resolve this Bill, or have I wasted my time?
Lee,
I appreciate your interest. I've been distracted with some new assignments this week and some health issues. I plan to get back on this by Monday. The users are presently satisfied but that won't last long. Thanks again.
