Hi, all,
I have a plotting issue I cannot resolve. Basically, my plotter is not plotting some bits of a drawing. Usually it just cuts 20% of it, sometimes it just doesn't plot some random objects.
any ideas how to fix it?
thank you
Without knowing if there is anything in common with the objects, it's hard to take a stab at what could be wrong.
Is it consistent? Is it always the same objects on a particular drawing that never plots? Does these objects plot on other plotters? on a PDF-printer?
Does the printer do the same from other computers? I.E. is it your computer that is the culprit, or the plotter.
Might there be erroneous do not plot settings on some of those layers? Or could they be viewport frozen layers perhaps?
Other computers seem to work fine. All layers, which need to be plotted are on, no frozen layers... Printing PDF was fine until yesterday morning.... I don't know what happened... I am trying to sort this out for several weeks now, even had my plotter driver re-installed to my computer, nothing seem to help. I will print one drawing and post it here, so you can see
