Regapp ID Cleanup Utility
Hello,
I only have C3D 2012 installed and I would like to get regapp cleanup to function. Does anyone have any success in this area?
Thanks,
Phil
I don't see a Regapp ID Cleaner listed under Utilities and Drivers at the AutoDesk website for anything beyond 2009.
Is this what you're after? :unsure:
(command "._-purge" "regapps" "*" "n")
ReMark - I can not find it anywhere for 2010 and newer.......
RenderMan - That is exactly what I am looking for.............. but with a GUI and the ability to do entire directories at a single time without opening autocad.
thank you both for the replies, much appreciated
Now you're adding parameters which reduce the available (possible?) solutions... Welcome to the world of .NET development with RealDWG, I'd suggest a Windows Forms, or WPF Application to be your starting point.
FWIW - Were you to deem it acceptable to open AutoCAD, then you could use an ObjectDBX wrapper (Lee's?) to process entire directories at a time.
RenderMan,
thanks for the options and assistance.
Phil
Happy to help. :)
