sandiegophil Posted May 25, 2012 Posted May 25, 2012 Hello, I only have C3D 2012 installed and I would like to get regapp cleanup to function. Does anyone have any success in this area? Thanks, Phil Quote
ReMark Posted May 25, 2012 Posted May 25, 2012 I don't see a Regapp ID Cleaner listed under Utilities and Drivers at the AutoDesk website for anything beyond 2009. Quote
BlackBox Posted May 25, 2012 Posted May 25, 2012 Is this what you're after? (command "._-purge" "regapps" "*" "n") Quote
sandiegophil Posted May 25, 2012 Author Posted May 25, 2012 ReMark - I can not find it anywhere for 2010 and newer....... RenderMan - That is exactly what I am looking for.............. but with a GUI and the ability to do entire directories at a single time without opening autocad. thank you both for the replies, much appreciated Quote
BlackBox Posted May 25, 2012 Posted May 25, 2012 RenderMan - That is exactly what I am looking for.............. but with a GUI and the ability to do entire directories at a single time without opening autocad. Now you're adding parameters which reduce the available (possible?) solutions... Welcome to the world of .NET development with RealDWG, I'd suggest a Windows Forms, or WPF Application to be your starting point. Quote
BlackBox Posted May 25, 2012 Posted May 25, 2012 FWIW - Were you to deem it acceptable to open AutoCAD, then you could use an ObjectDBX wrapper (Lee's?) to process entire directories at a time. Quote
sandiegophil Posted May 25, 2012 Author Posted May 25, 2012 RenderMan, thanks for the options and assistance. Phil Quote
BlackBox Posted May 25, 2012 Posted May 25, 2012 thanks for the options and assistance. Happy to help. Quote
