Exploding Wide PLINEs of Varying Widths
Has anyone come up with a way to explode varying width PLINEs ( Heavy or Light ) into LINEs and ARCs and maintaining it's outline? TRACEs or 3DFACEs would work just as well. It's the edges I need to access. And it doesn't have to be all that accurate.
I can do consistent width entities, not variable.
Thanks -David
PS: any Release of ACAD would be fine
WPLINE.DWG
That's a possibility. I would want to plot a single entity. But that might be doable.
UCS ....
Elevation ...
Thickness ...
They could be problems.
Thanks! -David
I don't know whether you are looking for a graphical solution or a Lisp solution.
But for a graphical solution, I tampered with Express Tools Text explode, so that it explodes lines. The picture shows an exploded polyline (which then separates into closed polylines similar to the outcome of TextExplode). Then I drew a rectangle to contain the Boundary polyline, which shows the edges.
Explore WMFOUT and WMFIN.
I remember a similar request at Autodesk Forum, but I can't find it.
The solution was to draw 2 new polylines, tracing polyline's outline.
That is the procedure used by TextExplode, which has the added advantage of keeping the scale :D
I don't anything on text explode ( 2012 ). Sorry
Graphical wouldn't be my 1st choice, but may be a solution, although very time consuming.
Thanks -David
Wow. i did not know that. :thumbsup:
Thanks -David
I probably did not say it quite right the first time, but I tweaked TextExplode to give me a lisp to explode lines. TextExplode does NOT do that.
This a link to where I posted it before
