Hi!
I realy don't know where to look anymore, so plese help me with this.
I need to have hidden lines on a 3D object dashed. So basically I need all the lines but those lines that are at the back of a cube(wich are normaly hidden), they need to be dashed. See the attachment
Help will be appreciated
forum.dwg
You will have to change the value of the system variable VSOBSCUREDLTYPE. A value of 2 will give you a dashed line but so will others (the length of the dash changes). Consult your AutoCAD Help file regarding the values (1-11) and what linetype is associated with each.
Edited by ReMark
Corrected TYPO!
You will have to change the value of the system variable VPOBSCUREDLTYPE. A value of 2 will give you a dashed line but so will others (the length of the dash changes). Consult your AutoCAD Help file regarding the values (1-11) and what linetype is associated with each.
VSOBSCUREDLTYPE (VS... INSTEAD OF VP...) ftfy
Also op may need VSOCCLUDEDLTYPE = 2 ftfm
and VSOCCLUDEDEDGES = 1
Welcome to the forum. :)
I notice that your profile says you are using 2012.
If you are working with 3D objects, and are not yet familiar with the VIEWBASE functionality which was introduced in 2012, I suggest you check it out.
And why would you be recommending that?
Because the OP is asking about representing 3D objects using 2012, not specifically as a fix to the stated issue.
As a conspicuous advancement in Autocad's ability to create 2D representations of 3D objects it doesn't seem entirely inappropriate.
This is not meant to refute your and rkent's posts, just a heads-up.
Did you download and open the drawing?
No I didn't, confident that you and rkent seemed to have already solved the specific problem.
Mistaken assumption?
In light of that fact I thought it more useful to offer some potentially new and useful information, than rehashing a solved problem. :beer:
Since the OP hasn't come back with any further questions I assume he got what he came for from one of us or all of us. Who knows?
It certainly looked to me like you guys had nailed it.
