guigol Posted June 29, 2012 Posted June 29, 2012 hi, First of all, sorry for my poor english. I've joined a dwg files for a better comprehension of my "problem". http://www.grosfichiers.ch/index.php?option=com_grosfichiers&cid[]=n0pp6olmgclaoei1cn2uko9dl4&task=resultat on this file you will see lot of objects (points in fact). I would like to replace them by text. just the number "1" I don"t want to give attributes, or modify the points. I just want to delete each point and replace it by a 1. I don't think there is a function to do it. I tried to write a lisp routine but i didn't succeed. Is there someone here who have allready develop a such routine? Thank in advance for your help Quote
ReMark Posted June 29, 2012 Posted June 29, 2012 I'm pretty sure I've seen this question before, maybe asked in a slightly different manner, but I think one of the lisp gurus here came up with a solution via a custom routine. I'll have to search around and see if I can find the thread. Quote
marko_ribar Posted June 29, 2012 Posted June 29, 2012 (vl-load-com) (defun c:p2t ( / msp ss txtsize n entpt pt txt ) (setq msp (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))) (while (not ss) (prompt "\nSelect points to replace with text \"1\"") (setq ss (ssget ":L" '((0 . "POINT")))) ) (initget 7) (setq txtsize (getreal "\nInput text height : ")) (repeat (setq n (sslength ss)) (setq entpt (ssname ss (setq n (1- n)))) (setq pt (cdr (assoc 10 (entget entpt)))) (setq txt (vla-addtext msp "1" (vlax-3d-point pt) txtsize)) (vla-put-alignment txt 10) (vla-put-textalignmentpoint txt (vlax-3d-point pt)) (entdel entpt) ) (princ) ) M.R. Quote
ReMark Posted June 29, 2012 Posted June 29, 2012 I guess I can stop looking. That's pretty quick service there marko. guigol you should tell your friends to visit CADTutor. Quote
