Greetings,
1st let me preface this with the fact that I know zilch, nada, nil about solid modeling. But I think the easiest way to accomplish what I'm trying to do is thru solid modeling and export the end result as (3D) polyline
What I have is 2 intersecting arcs with varying radii and ucs values. I'm guessing these could turned into regions and then subtract 1 from the other in order to find a list of intersecting points or maybe a splined pline. Or maybe they could be joined. Either way, if I DXFOUT the solids in R12 format, they become plines
I have access to R14 thru 2012
My attempts at have been very disappointing ( but expected )
Any suggestions would be greatly appreciated. -David
-ARCINT.DWG
Do you have access to Autodesk Inventor?
Inventor has had this tool for years
Attach your dwg file here - maybe I can figure out something in AutoCAD with xedges.
Oops, I see you did attach the file. Let me see what I can figure out.
Uhmmm,
list indicates those are arcs with thickness.
Don't do that.
Extrude them as surfaces.
Trim one of the surfaces with the other.
Change active color.
xedges
Thanks! -David
I did Extrude ( 2 arcs ) -> Union ( 2 surfaces ) -> xedges ( returned (1) spline (4) arcs and (4) lines) Very cool!
Edited by David Bethel
Correction UNION not JOIN
But did you actually get it? That was pretty fast.
David, I removed the thickness from both arcs, added some polylines to each arc so they both would become closed polylines, extruded both, subtract one from the other and saved as R12 DXF. Then, I open the dxf drawing and saved it as dwg. Attached.
Paul
-ARCINT.dwg
Sounds like a lot of extra work?
You are correct JD. A lot of extra work.
Yes! it actually worked. I didn't quite expect xedges to make every edge for both solids, but it will be useful to me. Thanks! -David
Paul
HHMMMM I'll have to figure what that 1 does. Thanks! -David
I know it may not look like a big thing, but it is the top eyebrow shelf that is the final result. Thanks again. -David
Now that I see what you were creating - I would have simply done two solid extrusions and intersect.
I should have warned you about xedges, but I also said extrude arc surfaces, not solids.
