Okay, can anyone tell me is there is a way to etransmit more than 1 drawing (over 100 files) in a faster more efficient way instead of opening every separate file and etransmitting file by file?
  • 3 weeks later...
are you binding the drawings when you etransmit? or are you sending all xref's seperatly also?
The zip file contains the drawing as well as the attached xref, so yes.
