vdubber87 Posted September 23, 2012 Posted September 23, 2012 Hi, I'm new to the forum as well as to autocad. I have a one problem: I am trying to draw a floor plan, that has one side 90' long. When I change the units to Architectual>inches, and then enter 90' as my line length, the line becomes way too long to fit on the screen. This is clearly some sort of a scaling issue. Any help is greatly appreciated. Thanks Quote
ReMark Posted September 23, 2012 Posted September 23, 2012 Well you at least got the model space part correct. Always draw your model space objects at FULL size. However, when it comes to paper space now you should be using viewports and it is the viewport that a scale is assigned to. Since you are using imperial units (architectural) you should know that floor plans are usually plotted at 1/4"=1'-0" scale or 1/8"=1'-0". Part of this is dependent on the size of the paper you will be plotting to. Quote
vdubber87 Posted September 23, 2012 Author Posted September 23, 2012 Thanks for your reply. I tried this, but didn't seem to do much. I'll try explaining further: If I open the finished drawing (posted by the tutorial author), and move the mouse a few mm, the coordinate units change by A LOT (which is what I need). If, I open MY drawing model space, the units don't change NEARLY as much by moving the mouse a few mm. Quote
ReMark Posted September 23, 2012 Posted September 23, 2012 Let's clear something up right from the start. You are using "architectural" units (imperial) but you are, in your own words, moving the mouse a few mm (metric)? Something is wrong. Quote
vdubber87 Posted September 23, 2012 Author Posted September 23, 2012 ok, for every inch that I move the cursor on the COMPLETED drawing's model space, the numbers change by a 100x more, compared to MY model space. So I want to know how to set that on MY drawing as well. Quote
ReMark Posted September 23, 2012 Posted September 23, 2012 You used the phrase "model space' to describe both situations. Quote
vdubber87 Posted September 23, 2012 Author Posted September 23, 2012 #1 MODEL SPACE: move cursor 1 inch, units change from i.e 100.000 - 101.000 #2 MODEL SPACE: move cursor 1 inch, units change from i.e 100.00-200.000 How do I make #1 the same as #2? Quote
ReMark Posted September 23, 2012 Posted September 23, 2012 It's been a confusing day. How many drawings are you working with here? Two? How about you post the drawing(s) and we'll take a look at them. Quote
vdubber87 Posted September 23, 2012 Author Posted September 23, 2012 ok I'll try to figure it out, and if I can't, I'll do that. Thanks a lot for your help! Quote
ReMark Posted September 23, 2012 Posted September 23, 2012 You didn't happen to enable SNAP by any chance. Quote
vdubber87 Posted September 23, 2012 Author Posted September 23, 2012 No, this is some scaling issue. Thanks! Quote
ReMark Posted September 23, 2012 Posted September 23, 2012 Are you using paper space and a viewport at all? Quote
vdubber87 Posted September 23, 2012 Author Posted September 23, 2012 No, not familiar with those yet. I am just using model space. I'm following the tutorial at http://www.we-r-here.com! Quote
ReMark Posted September 23, 2012 Posted September 23, 2012 You have already set your units to architectural via the UNITS command right? And the tutorial instructs you to draw a line 90 feet long. Yes? Quote
vdubber87 Posted September 23, 2012 Author Posted September 23, 2012 I solved it! I just had to do Z > Scale > 0.1 THANKS! Now you can explain what that does haha? Quote
vdubber87 Posted September 23, 2012 Author Posted September 23, 2012 Hm, that just seems to zoom out the object by a certain scale. Not quiet what I need! I'll look into it some more. Quote
ReMark Posted September 23, 2012 Posted September 23, 2012 How about doing a Zoom > All? Can you see your whole line now? Quote
vdubber87 Posted September 23, 2012 Author Posted September 23, 2012 Yes...I get it now. It's a zooming issue, and once I zoom>All, it adjust the scale for that! Thanks Quote
ReMark Posted September 23, 2012 Posted September 23, 2012 I think you figured it all on your own. Good. Quote
