I need select a Polyline with a variable,
This code is ok!
(setq selpline (ssget "_x" '((0 . "LWPOLYLINE")(8 . "First"))))
I need convert to:
(setq cod "Second")
(setq selpline (ssget "_x" '((0 . "LWPOLYLINE")(8 . cod))))
But this code return
Command: ; error: bad SSGET list value
I need help to make this code.
Thanks
Rodrigo
The name of the layer should be string like the first line of code you brought .
(8 . "cod")
http://www.cadtutor.net/forum/showpost.php?p=258390&postcount=20
if i use
(setq valor "X1")
(setq selpline (ssget "_x" '((0 . "LWPOLYLINE")(8 . "valor"))))
The lisp does not recognize the value of the variable
If use variable with "" the lisp recognize VALOR and not X1
Any help?
if i use
(setq valor "X1")
Any help?
Hola . :)
It should like this .
(setq valor "X1")
(setq selpline (ssget "_x" [b](list[/b] '(0 . "LWPOLYLINE")([b]cons[/b] 8 valor))))
if i use
(setq valor "X1")
Any help?
Did you read the post I linked to?
