gazane Posted February 1, 2013 Posted February 1, 2013 Hello, I would like to know if it is possible to fill the attributes of one block automatically, using a Script maybe, or a program that completes the attributes using informations that are in a excel sheet. Is that possible ? Thanks. Quote
KFW Posted February 1, 2013 Posted February 1, 2013 diesel function fields lisp like http://www.lee-mac.com/updatetitleblock.html What kind of block and attributes? Quote
gazane Posted February 1, 2013 Author Posted February 1, 2013 Thanks, I will read more about it. The block is one kind of product, but in the same draw there are equal blocks, but with different attributes. The attributes are ID, product code and other things. Quote
BIGAL Posted February 2, 2013 Posted February 2, 2013 Two ways read direct from excel or create a csv data file that is read by a lisp. Best answer of the whole lot this question has been answered so many times previously here so use the search function start with "Excel" be warned like I said its will return lots of posts so be patient. Google excel to autocad update attributes Quote
dbroada Posted February 2, 2013 Posted February 2, 2013 gazane, what you have been asking over the past few days are all relatively easy to do but you seem to be asking little bits of a bigger question. I don't know if you are trying to get an insight into what can be done in LISP or are after a total solution to your problem. Can you explain what you are trying to achieve. Whether you are wanting to learn or want a complete solution the final advice will be much more tailored to your needs. If you want to learn lisp I am sure somebody will talk you through the step. If you want a solution I am sure somebody will offer it. But asking in little bits can give you lots of answers that don't play nicely with each other. Quote
