Digidoug Posted July 19, 2012 Posted July 19, 2012 My question is, How can I rotate points. I have tried the align command which rotates the text associated with the points but it does not rotate the actual points. The point database remains unchanged. Is there a way to rotate points? Quote
Guest AARi Posted February 17, 2013 Posted February 17, 2013 have a look this into C3D, may be you can export rotated-points into LandDesktop. [located into the end of prospector-table] AARi Quote
BIGAL Posted February 18, 2013 Posted February 18, 2013 You can rotate the points and rotate there lable, a couple of ways Using the Toolspace Points you can edit 1 point go to the right hand end last two boxes are pt & lable look above. Pick a point right click mouse a choice comes up including rotate a point . 3rd I am pretty sure you can do as part of point description our surveyor does this for us so already rotated. 4th some lables and styles can be set to follow view this way is always sq to page no matter what ucs is used. 5th you can via lisp alter points so could do say swing 90 pick point etc. This was a post for elev text to align to 3d lines recently. Quote
