Hi, I have an issue with a file when I plot only.
The black 'mask' appears only after plotting. It does not show up in print preview.
There are no frozen layers or switched off through viewports.
When I open the viewport on a new paperspace page it follows me in. I can only assume there is an underlying mask in model space or paperspace.
Thank you for reading my question and your help is very much appreciated.
George.
Can you attach a copy of a drawing that exhibits the strange behavior to your next post?
Sounds like you may have a Wipeout in your drawing. :unsure:
Type WIPEOUT at the command prompt and then type "F" for Frames and then "ON" to enable the Wipeout frame to be displayed. Do you now see a rectangle where the black region displays on your printout? If so, select it and delete it.
