Nayfb Posted June 13, 2013 Posted June 13, 2013 When i attempt to open a dxf file in autocad it comes up with error messages; Class not registered any idea's? thanks in advance Quote
rkmcswain Posted June 13, 2013 Posted June 13, 2013 Did you create the DXF? Can you post it here? Quote
Nayfb Posted June 13, 2013 Author Posted June 13, 2013 Did you create the DXF?Can you post it here? I sure can mate, ta Stedmark 960x240x5.dxf Quote
Murph_map Posted June 13, 2013 Posted June 13, 2013 I sure can mate, ta It opened fine with me, what app are you using to open it, Vanilla AutoCAD, Civil3d, ADT ? Quote
Nayfb Posted June 13, 2013 Author Posted June 13, 2013 I'm using Autodesk Autocad 2013 I know it should work as i have done it so many times before on another system. But i am on a different PC at the moment and it wont allow me to :/ thanks Quote
rkmcswain Posted June 13, 2013 Posted June 13, 2013 It opened fine for me on C3D2013 SP2. Does it give you a "line" where the error is occurring? Is there any other info other than "class not registered"? Quote
ReMark Posted June 13, 2013 Posted June 13, 2013 No problem here opening your file using plain old AutoCAD 2013 SP 1.1. Quote
Nayfb Posted June 14, 2013 Author Posted June 14, 2013 You wont believe this but it's just started working randomly. Not sure why i haven't changed anything but it just opened one no problem. haven't changed anything, just gave it a night to itself and now works :S Ty anyway Quote
Nayfb Posted June 17, 2013 Author Posted June 17, 2013 Maybe it's your computer. What are the specs? BitFenix Prodigy Mini-ITX Z77 - Arctic White, Intel Core i5-3570 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W), Gigabyte Z77N-WIFI Intel Z77 (Socket 1155) DDR3 Mini ITX Motherboard, KFA2 GeForce GTX 560Ti LTD OC 1024MB GDDR5 PCI-Express Graphics Card - White Edition, Corsair Vengeance Arctic White Low Profile RAM 16GB, Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache, BitFenix Spectre PRO 230mm fan - white, Corsair Enthusiast Series TX650M High Performance 650W '80 Plus Bronze' Modular Power Supply. So not a light duty PC, i use it for gaming and graphic design etc also. God knows, thanks alot for your helping in the matter regardless. Quote
