3d solids to blocks
JamesBorubar
  • Replies 33
  • JamesBorubar
    15
  • SLW210
    5
  • halam
    4
  • ReMark
    3
Posted Images
I'm not sure what sort of answers you're looking for? Are you looking for information about how to create a block or are you looking for a way to replace your existing 3D solids with block instances or are you looking for an explanation about why you should use blocks?
Can you clarify your question?
That is complicated. You have be able to filter based on volume and calculate the centre point first..
Why do you need it (this way)??
Cad64,
I'd like to know the easiest way to convert repeating 3solid to one block.
I've got filter- thank you halam again.
There are 2 reasons:
1. I want reduce size of file
2. Preparation for import into Inventor
Cad64,
Why wouldn't you just use the BLOCK command? There is no "converting". If the block is going to be used in multiple drawings then use the WBLOCK command.
I think he wants to replace existing solid models with block instances. For example, if he has 100 individual nuts, washers & bolts in his model, he wants to automatically replace all those individual parts with block instances. I don't know how to do that without the aid of a custom lisp routine, but even then, I think it would be quite difficult to precisely replace the solids with block instances, taking into account the exact position, rotation and alignment of each solid.
This is why it's important to have a game plan before you start building a model. If you know you're going to have repetitive items, like nuts & bolts, create blocks in the beginning. Trying to go back now and replace everything with blocks is going to be a chore and something you will probably have to do manually.
1. How did the file size get out of hand?
To me it sound you are dealing with 3d collections as a result of other software. Why didn't you used blocked 3d element to start with? What is the background? (just asking because this replacements method maybe can be done smarter than 3d solid) filter by material can be a trick here.
Yes, of course, you are right, it isn't actually conversion, just making blocks.
I am looking for tool similar to that: http://www.cadforum.cz/cadforum_en/simplifying-3d-drawings-by-replacing-repeating-3d-solids-blocks-tip10802
but without restrictions.
I've got ready 3d model with 3d solids.
I don't care about bolts and nuts, just for plates and RHS's sections
Edited by JamesBorubar
mistake
And how does that routine restrict you?
The application doesn't support combined 3D solids (3DSolid) created e.g. using boolean operations, only boxes, cylinders and other primitives.
Intressting routine, but i could not get it to work.
modelled 5 cubes all 1.0 m3 but is doesn't seem to work.
How does this routine work? What does it calculate to check for equility? (i was thinking : volume and boundingbox?)
It works, but only with sample drawing Kvadry.DWG ...
I think that I can compare (2) 3D Solids and tell if they are identical geometry, layers, color etc. I cannot tell you where they are located .
Draw (2) 3D SPHEREs with the same diameter, only different locations.
[b][color=BLACK]([/color][/b]defun c:c3d [b][color=FUCHSIA]([/color][/b]/ ss e1 e2 d1 d2 c1 c2 rl[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]not e1[b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]princ [color=#2f4f4f]"\nSelect 2 Entities:   "[/color][b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]and [b][color=MAROON]([/color][/b]setq ss [b][color=GREEN]([/color][/b]ssget[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]= [b][color=GREEN]([/color][/b]sslength ss[b][color=GREEN])[/color][/b] 2[b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]setq e1 [b][color=GREEN]([/color][/b]ssname ss 0[b][color=GREEN])[/color][/b]
                   e2 [b][color=GREEN]([/color][/b]ssname ss 1[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]not [b][color=GREEN]([/color][/b]eq e1 e2[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
             [b][color=MAROON]([/color][/b]setq d1 [b][color=GREEN]([/color][/b]entget e1[b][color=GREEN])[/color][/b]
                   d2 [b][color=GREEN]([/color][/b]entget e2[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]setq rl [b][color=NAVY]([/color][/b]list -1 5 330[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]foreach g d1
   [b][color=NAVY]([/color][/b]if [b][color=MAROON]([/color][/b]not [b][color=GREEN]([/color][/b]member [b][color=BLUE]([/color][/b]car g[b][color=BLUE])[/color][/b] rl[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
       [b][color=MAROON]([/color][/b]setq c1 [b][color=GREEN]([/color][/b]cons g c1[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
       [b][color=MAROON]([/color][/b]setq c2 [b][color=GREEN]([/color][/b]cons g c2[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]if [b][color=NAVY]([/color][/b]equal c1 c2[b][color=NAVY])[/color][/b]
     [b][color=NAVY]([/color][/b]alert [color=#2f4f4f]"SOLIDs Are Indentical"[/color][b][color=NAVY])[/color][/b]
     [b][color=NAVY]([/color][/b]alert [color=#2f4f4f]"SOLIDs Are NOT Indentical"[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
Without the location information, I don't know if it could be done. -David
And I do mean identical. Not rotated, not different elevations etc
I would just make it a block and locate them manually, just try to make the insertion point of the block something logical for locating.
Is there a particular relationship between the solids?
Just post a drawing that shows what is needed, might help with better solutions.
