Send to PDF
GregGleason
I have written a send a .dwg to .pdf routine and it is not working.
Here are the plot settings.
Any ideas?
(defun c:SendToPDF ( / *error* vars old s file Fname fsl dwgN)
  (defun *error* ( msg )
     (and old (mapcar 'setvar vars old))
     (princ (strcat "\n** Error: " msg " **")))
  (setq vars '("CMDECHO" "FILEDIA") old (mapcar 'getvar vars))
  (mapcar 'setvar vars '(0 0))
  (setq dwgN (getvar "dwgname"))
  (setq fsl (strlen dwgn))
  (Setq Fsl (- fsl 4))
  (setq Fname (substr dwgn 1 fsl))
  (setq Fname (strcase fname t))
  (setq file (strcat (getvar 'DWGPREFIX) (substr (setq dwg (getvar 'DWGNAME)) 1 (- (strlen dwg) 4)) ".pdf"))
  (while
        (setq s (getstring (strcat "\nEnter Filename for Save <" (getvar 'file) "> : ")))
        (cond ( (eq "" s)
        (setq s (getvar 'DWGNAME)) nil)
        ( (not (snvalid s))
        (princ "\n** Invalid **")))
(setq path (getvar "dwgprefix"))
; (command "_.saveas" "_2010" (strcat "G:\\Group\\2D AutoCAD\\HDAL Library\\" s))
;(command "_.saveas" "_2007" (strcat path s))
 (command "-plot"         "yes"           ""              "DWG TO PDF.PC3"
          "ANSI expand B (11.00 x 17.00 Inches)" "Inches"        "Landscape"     "yes"           "Extents"
          "yes"           "yes"               "yes"           "monochrome.ctb"       "yes"
          "no"            "no"            "yes"           file            "no"            "Yes"
Greg
I'm not sure because I haven't tested your routine but does it maybe fail on the paper size? You don't mention... I ask because I had this problem once and after I replaced the spaces in my paper size with underscores it worked...
Thanks. I will give that a shot and see what happens.
Greg
GregGleason,
try this.
(defun c:Test()
     (vl-load-com)
     (if (setq filename (getfiled "Save File Location" ""  "pdf" 1))
     (command "-plot" "yes" "" "DWG To PDF.pc3" "ANSI expand B (11.00 x 17.00 Inches)"
         "inches" "landscape" "yes" "Extents"
         "fit" "center" "yes" "monochrome.ctb" "yes" "a" filename "no" "yes")
Probably Brian's suggestion will work so just show where you went wrong:
to make the file name try his :
 (setq file (strcat (getvar "dwgprefix") (vl-filename-base (getvar "dwgname")) ".pdf"))
also :
file is not a system variable so it should be :
 (setq s (getstring (strcat "\nEnter Filename for Save <" file "> : ")))
hope this helps
gr. Rlx
2c - I'd store the file lisp variable like this:
(setq file (apply '(lambda (a b c) (strcat a b ".pdf")) (fnsplitl (apply 'strcat (mapcar 'getvar '(dwgprefix dwgname))))))
make it 20 dollar cause never seen this construct :? haha
GregGleason,
try this.
(defun c:Test()
     (vl-load-com)
That worked great BrianTFC! I appreciate the help.
Greg
also :
hope this helps
gr. Rlx
I appreciate you taking the time to show me these. THIS is how I learn. Kudos to you, rlx!
Greg
Greg,
Your welcome Greg!! I've leaned a lot from everyone on this site and I'm glad I could finally help someone on here.
Brian
  • 1 year later...
finally managed to get this all setup and working properly using the getvals, plota3pdfrange etc. one thing i noticed with the merging of the pdf's though, it seems to change the appearance of symbols in text. my diameter symbol for example looks fine in the individual sheets but once combined it changes..
single pdf sheet like this:
after its combined it looks like this:
anyone know how to fix this? I've got latest version of ghostscript installed
Edited by masterfal
yeh usually use %%c.
it only happens when i use the arial font. if i change to calibri it works. need to use arial though as thats our standard style..
Trying to remember pretty sure arial has a diameter symbol. Go to mtext pretyy sure the key code is there. Go down to other and it will open the font map need to work out the key number.
Edited by BIGAL
