PJ01 Posted July 8, 2018 Share Posted July 8, 2018 (edited) In the drawing attached below, there are 4 lines of text shown above the title. The last 2 lines were added recently. When I print out the drawing from the Layout1 view, the last two lines of text ( specifying the dimensions of the sides and the base) do not appear on the printed output. Similarly, if I export the drawing in a .pdf format, the two lines of text are also missing. Also, the bottom two lines of text do not appear in the Print Preview. I have tried double clicking on the Layout1 page, saving again, zooming, shutting down and restarting the program, to no avail. Can anyone please advise why this might be happening, and how to overcome it? Helena_ Notepaper Holder.dwg Edited July 8, 2018 by PJ01 Quote Link to comment Share on other sites More sharing options...
nukecad Posted July 8, 2018 Share Posted July 8, 2018 I can't open your drawing on this laptop to check, but the most common cause of this is that the text is on 'layer 0' which never plots. Move it to a different layer. Second most common is that the text is on another layer that has been set not to plot. Again move it to a different layer, or turn on plotting for the layer that it is on. Third most common, if this text is in model space then maybe those two added lines have 'strayed' outside the paperspace viewport? Turn on the viewport outline in paperspace and check. If the text is falling over the boundry then make the viewport bigger, or move the text so it is fully inside the viewport. There may be another cause, but as I say I can't open the drawing on this laptop and the above are the three most common. Quote Link to comment Share on other sites More sharing options...
Dana W Posted July 8, 2018 Share Posted July 8, 2018 I can't open it either since I am at home, but maybe the text is color 255, the "other" white that does not change with the background. And layer 0, (zero) does plot, unless it is set not to. It is DEFPOINTS that doesn't plot, nor should it be used to draw or place any objects on so they won't plot. It is a system layer that should be left alone. Quote Link to comment Share on other sites More sharing options...
eldon Posted July 8, 2018 Share Posted July 8, 2018 That text currently has a colour 255 and is on layer DIM. Set the colour to Bylayer, unless you want it not to print. Quote Link to comment Share on other sites More sharing options...
nukecad Posted July 8, 2018 Share Posted July 8, 2018 And layer 0, (zero) does plot, unless it is set not to. It is DEFPOINTS that doesn't plot, nor should it be used to draw or place any objects on so they won't plot. It is a system layer that should be left alone. Thanks for the correction, like everyone else my brain sometimes gets in front of itself. (It was always 'good practice' never to draw anything on layer 0 and have it turned off for plotting. Of course what is 'good practice' changes over the years as AutoCAD versions change). Quote Link to comment Share on other sites More sharing options...
Dana W Posted July 8, 2018 Share Posted July 8, 2018 Thanks for the correction, like everyone else my brain sometimes gets in front of itself.(It was always 'good practice' never to draw anything on layer 0 and have it turned off for plotting. Of course what is 'good practice' changes over the years as AutoCAD versions change). It's still good practice to not use it for drawing, but to inform the novices reading... Creating geometry in blocks on Layer 0 is good because they will take on the properties of any other layer the block is inserted on. You can include geometry in blocks on other layers too, but those object properties will not change when inserted on other layers. Quote Link to comment Share on other sites More sharing options...
PJ01 Posted July 8, 2018 Author Share Posted July 8, 2018 (edited) Thanks for your ideas and suggestions, folks, I really apprecaite them. I have changed the colour to By Layer, and still the bottom 2 lines do not print. I have attached print screens of the various pictures which may shed some light: 1. Print Preview 2. Properties of the upper 2 lines of text 3. Properties of the lower 2 lines of text ( these were a separate multiline text addition, not an extension of the upper text) 4.The Layout1 view, showing Viewport boundary Edited July 8, 2018 by PJ01 Quote Link to comment Share on other sites More sharing options...
Cad64 Posted July 9, 2018 Share Posted July 9, 2018 As Eldon mentioned, your Mtext is set to color 255,255,255, see image below. Double click on the Mtext, highlight all the text and then change it to ByLayer where I have indicated within the red box. Once you do this, your Mtext should change to red and you should see it when you plot. Quote Link to comment Share on other sites More sharing options...
PJ01 Posted July 9, 2018 Author Share Posted July 9, 2018 (edited) Many thanks for doing this, Cad64, very much appreciated. As you can see in the post immediately before yours, I had changed things from my original .dwg posted by using the Outline layer ( not the red Dim layer) and changed the Mtext by selecting the two lines of text, going into Properties and changing the Colours to By Layer. Obviously that did not work, as I still could not see the 2nd row of text. Strange!! In the end I changed it in the Text Editor as you indicated, and the two lines of print appeared in Print Preview. YESS!!!!! All this problem printing lines came about because I entered the lines of text while in the Dim layer Edited July 9, 2018 by PJ01 Quote Link to comment Share on other sites More sharing options...
eldon Posted July 9, 2018 Share Posted July 9, 2018 If you look at the Content section of the properties of the affected text, you can see some format statements before the actual text {\C0,\c16777215; That gives a clue that something is amiss. Quote Link to comment Share on other sites More sharing options...
PJ01 Posted July 9, 2018 Author Share Posted July 9, 2018 Thanks everyone, I have learnt lots from this, although I still don't know why changing the Mtext Properties of the selected lines of text did not work. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted July 9, 2018 Share Posted July 9, 2018 Thanks everyone, I have learnt lots from this, although I still don't know why changing the Mtext Properties of the selected lines of text did not work. It didn't work because the color property was overridden in the text editor. I know, it's a little confusing. You can set your layer color in the Layers palette, and you can override the layer color by changing the object color in the Properties palette, but then you can override the override in the text editor. Quote Link to comment Share on other sites More sharing options...
PJ01 Posted July 10, 2018 Author Share Posted July 10, 2018 Thanks for this explanation, Cad64. I know what to do next time if it ever crops up. Text Editor is KING !! Thanks to eldon too, for his tip about checking the Content in the Mtext Properties menu Quote Link to comment Share on other sites More sharing options...
eldon Posted July 10, 2018 Share Posted July 10, 2018 You could have also Exploded that Mtext. This gets rid of any embedded formatting, and the colour can be changed to Bylayer, but it is no longer Mtext. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 10, 2018 Share Posted July 10, 2018 You can have a look at THIS for Stripping the formatting from MTEXT. Quote Link to comment Share on other sites More sharing options...
