#1 |
Forum Newbie
Using: AutoCAD 2009 Join Date: Oct 2009
Any of you guys seen this?
I am trying to use the GATTE command that I have been using for YEARS!! If if pick the block I get this Command: gatte Initializing... Select block or attribute [Block name]: Block: Meridian_a1_sheet Attribute tag: TUK-SUB-TY-NO Enter new text: *Cancel* and I can then type in the changes Command: `*Cancel* if I try to do it on the command line - I get this Command: GATTE Select block or attribute [Block name]: b Enter block name: Meridian_a1_sheet Known tag names for block: REV_6_DATE REV_6_APP REV_6_CONTRACT REV_6_COMPANY REV_6_CHECKED_BY REV_6_BY REV_6_DETAIL REV_6 REV_5_DATE REV_5_APP REV_5_CONTRACT REV_5_COMPANY REV_5_CHECKED_BY REV_5_BY REV_5_DETAIL REV_5 REV_4_DATE REV_4_APP REV_4_CONTRACT REV_4_COMPANY REV_4_CHECKED_BY REV_4_BY REV_4_DETAIL REV_4 REV_3_DATE REV_3_APP REV_3_CONTRACT REV_3_COMPANY REV_3_CHECKED_BY REV_3_BY REV_3_DETAIL REV_3 REV_2_DATE REV_2_APP REV_2_CONTRACT REV_2_COMPANY REV_2_CHECKED_BY REV_2_BY REV_2_DETAIL REV_2 REV_1_DATE REV_1_APP REV_1_CONTRACT REV_1_COMPANY REV_1_CHECKED_BY REV_1_BY REV_1_DETAIL REV_1 REV_MAIN SUP-DWG-NAME SUPPLIER_NUMBER DESIGNER TUK-SUB-TY-NO TITLE_3 TITLE_2 TITLE_1 PROJECT_NAME Select attribute or type attribute name: project_name *Invalid selection* Expects a point or RE I was very confused as what is RE? but its the first two characters of REV_6_DATE in the list of known tags sometimes I get a list like REV_6_DATE/REV_6_APP/REV_6_CON but even then typing in REV_6_DATE does not enter the text into that attribute tab - whats gone wrong with GATTE in MAP2009 Steve Muller New Zealand |
#2 |
Forum Newbie
Having compared some other files the only thing different I can see is the Variable DBMOD. - though this is a read only variable.
#3 |
Senior Member
![]() ![]() ![]() Using: AutoCAD 2010 Join Date: Mar 2009
Hello,
When it comes up with Expects a point or RE basically it is the start of your list of attributes but it can't fit it on the screen. eg. if you type Code:
(initget "Hello there") (nentselp) "w" As for your other GATTE trouble, you might have to post the drawing (if it's small). |
#4 |
Forum Newbie
Yup Steve - it sure does
Select object: "w" *Invalid selection* Expects a point or Hello/ther Drawing attached. Cheers Steve Muller |
#5 |
Forum Newbie
OK - its something to do with the DWG not my system. I inserted another companies title block into the same DWG above and I can use GATTE like its spoze to. Steve M
#6 |
Senior Member
Hi, Further digging around in the help file for initget has found the source of the problem:
Each keyword can contain only letters, numbers, and hyphens (-). For example: Code:
(initget "hel_lo there") (nentsel) "he" *Invalid selection* Expects a point or he Gatte uses this. So alternatives for you are to either select the attribute (rather than the block) or I made a program called gatte2 which doesn't use initget you might try instead. |
#7 |
Forum Newbie
Yup - correct all the attributes in the titles are like DFD_No_10 - looks like a little edit time for me - thanks muchly Steve M
| Thread Tools | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| GATTE 2 (Global Attribute Edit with Layout Select) | SteveK | AutoLISP, VBA, the CUI & Customisation | 6 | 5th Oct 2009 11:31 pm |
| GATTE not Working | nocturne00 | AutoCAD Drawing Management & Output | 1 | 24th Sep 2008 09:18 am |
| Looking for a working 286/386 | Between the Lines | AutoCAD RSS Feeds | 0 | 31st Aug 2007 08:01 pm |
| Why isn't this working? | Baçon | AutoLISP, VBA, the CUI & Customisation | 3 | 18th May 2005 10:17 pm |
