screwdriver.
jester[AUT]
HI!
This is the second time I work with rhino,so I need some tips to do this.
I have to model my screwdriver in 3d and I don't know with what I should begin.
my task is to take photos of my screwdriver and add them in the front, top, and right view. Then I change the picture size to the original size of the screwdriver...
I did that, but if I have the shade mode on I don't see the content of the picture and if I have the rendering view on I don't see the lines.
I dont know how to do the grip. It is round and has corner... maybe curves?
greeds,
jester
[ATTACH=CONFIG]33818[/ATTACH][ATTACH=CONFIG]33819[/ATTACH][ATTACH=CONFIG]33820[/ATTACH]
2 minutes in Gimp using edges filter
Thanks, but it is not really what I need. I need to now how to make the surface that it gets its special shape.
  • 2 weeks later...
;468366']what's the best way to do the yellow stripes on the grip?? cheers
Draw the stripes as 2d profiles and project them onto the handle.
Edited by dedmin
I need to do a smooth transition from one object to another. I ve parted my grip into two parts.
@ dedmin. thank you, dude. and thank you for your efforts to create an example.
blend [x]checked :D
the last step to model this work:
I would like to do the indentation of the red part in the image. it is a surface. every time I try to change it, it ends to a disaster. maybe i use the wrong tools.
[ATTACH=CONFIG]34182[/ATTACH]
how can I extrude them. If I try that, only the margins go up.
blend [x]checked
:D
paperclip.png Attached Images attachment.php?attachmentid=34226&stc=1&d=1334661462
Try offset surface
I ve made a rod and after that: "arraypolar"
finally i used fillet edge.
it doesnt look as well as on the picture, but it's ok.
I am still working on the stripes... I m attempting to make a patch surface...
  • 4 weeks later...
by the way: i ve also controlled my edges with the analys tool, so I can see which one is alone. Consequently, you can avoid terrible rendering results...
