Guest Alan Cullen Posted November 7, 2007 Share Posted November 7, 2007 Acad 2008. Does anyone know how to delete scales from the list Tools > Options > User Preferences > Edit Scale List ? I know how to pick them and delete them, but I want them to STAY deleted. With me, they all keep coming back the next day. There are soooo many of them, and we only use 10-15 set scales, so that is all I want showing up in the list. At the moment it takes forever to find the required scale amoung the millions that currently exist in that list. Quote Link to comment Share on other sites More sharing options...
riga Posted November 7, 2007 Share Posted November 7, 2007 Acad 2008. Does anyone know how to delete scales from the list Tools > Options > User Preferences > Edit Scale List ? I know how to pick them and delete them, but I want them to STAY deleted. With me, they all keep coming back the next day. There are soooo many of them, and we only use 10-15 set scales, so that is all I want showing up in the list. At the moment it takes forever to find the required scale amoung the millions that currently exist in that list. I have found right now a way to do that on my 2007 version: From Windows start > Run > regedit search for HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R17.0\ACAD-5001:409\Scale List Preset scales are listed with 3 value, like this example (for 1:40): 7. ScaleName REG-SZ 1:40 7. ScaleNumber REG-SZ 1.0000000 7.ScalePerUnits REG-SZ 40.0000000 Delete all 3 values, close regedit and restart your machine. Next start of Autocad scale 1:40 is gone Don't know the path for other versions because it will be probably different Let me know if it helps Quote Link to comment Share on other sites More sharing options...
Guest Alan Cullen Posted November 7, 2007 Share Posted November 7, 2007 Thanks Riga, that looks interesting. I'll try it out on my work computer tomorrow. If I have time tonight, I'll also try it here at home. I had heard that those scales are retained in the drawing, and if they are deleted in the template file, that would help a lot. But I haven't seen that yet. Quote Link to comment Share on other sites More sharing options...
riga Posted November 7, 2007 Share Posted November 7, 2007 Thanks Riga, that looks interesting. I'll try it out on my work computer tomorrow. If I have time tonight, I'll also try it here at home. I had heard that those scales are retained in the drawing, and if they are deleted in the template file, that would help a lot. But I haven't seen that yet. That's true. If you edit your scale list it will be saved in the drawing. However you can always restore the original list: Options > User Preferences > Edit scales list > Reset With the procedure I exposed above you are going to modify the scales list that will be restored. Edit scales list of templates seems a good idea BTW: as I know that a lot of you have Autocad 2008 I've asked a friends who work with that version and he said to me he can not find the scale list in the regitry Quote Link to comment Share on other sites More sharing options...
Guest Alan Cullen Posted November 7, 2007 Share Posted November 7, 2007 Yeah, maybe there is a difference here between 2007 and 2008, and the way they handle this issue. I have 2007 at home, and 2008 at work. I remember I never had this problem with 2007 at work. But I do now with 2008. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted November 7, 2007 Share Posted November 7, 2007 In 2008, the scale list drives the annotation scaling. See here for more info: http://discussion.autodesk.com/thread.jspa?messageID=5513146 Quote Link to comment Share on other sites More sharing options...
Guest Alan Cullen Posted November 7, 2007 Share Posted November 7, 2007 Thanks, Cad64, That just answered what I already suspected. I didn't realise that it was tied to associative scaling in 2008. But there you go. I'll look into that lisp and find out if it helps. In the meantime, many problems, and unwarranted hard work and repetitive resets with the scaling list. You would really think that AutoDesk would have thought this through a bit better. If it aint broke, don't fix it. Buggars. Anyway, cheers, mate, and thanks for the input. Quote Link to comment Share on other sites More sharing options...
NBC Posted November 7, 2007 Share Posted November 7, 2007 Obviously the tutorial i did for you Alan was pants, as i tried to pin down this scalelist to annotative scaling Quote Link to comment Share on other sites More sharing options...
Guest Alan Cullen Posted November 7, 2007 Share Posted November 7, 2007 ah, I missed that part, or did I? So you are saying it can be done? Quote Link to comment Share on other sites More sharing options...
Guest Alan Cullen Posted November 7, 2007 Share Posted November 7, 2007 Blue, the whole issue of scale list, is that it is kept per drawing. set it up in one drawing and it remains there. It doesn't work the same way it did in 2007. That is the pain. And it is all because (from what I gather) of annotative scaling. But that does not solve the problem from drawing to drawing. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted November 7, 2007 Share Posted November 7, 2007 You could add this to your "acaddoc.lsp" (command "-scalelistedit" "_r" "_y" "_e") Quote Link to comment Share on other sites More sharing options...
Guest Alan Cullen Posted November 7, 2007 Share Posted November 7, 2007 Oh, wow, McS. What does that code actually do? :D Quote Link to comment Share on other sites More sharing options...
NBC Posted November 7, 2007 Share Posted November 7, 2007 Oh, wow, McS. What does that code actually do? :D It resets the Scalelist to the default AutoCAD Scalelistedit, complete with imperial scales Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted November 7, 2007 Share Posted November 7, 2007 complete with imperial scales Unless you are in a metric drawing... Quote Link to comment Share on other sites More sharing options...
NBC Posted November 7, 2007 Share Posted November 7, 2007 Unless you are in a metric drawing... I am always in a metric environment, but resetting the scalelist always brings in imperial scales. it's a nuance of autodesk Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted November 7, 2007 Share Posted November 7, 2007 I am always in a metric environment, but resetting the scalelist always brings in imperial scales. it's a nuance of autodesk That is strange. If I run the NEW command and choose "No Template - Imperial", I get imperial scales. If I run the NEW command and choose "No Template - Metric", I get metric scales. Quote Link to comment Share on other sites More sharing options...
hazardman Posted February 2, 2008 Share Posted February 2, 2008 the units must be set to mm or m etc to give you metric scales... i have similar problems with the list where i get 1:10_xref_xref_xref and such and i remember reading on the autodesk forum somewhere that they can't replicate this bug and are asking subscriptioners to submit a report so they can look into it...sounds like the ol' layer filter thingy has morphed!.. Quote Link to comment Share on other sites More sharing options...
chulse Posted February 2, 2008 Share Posted February 2, 2008 the units must be set to mm or m etc to give you metric scales... i have similar problems with the list where i get 1:10_xref_xref_xref and such and i remember reading on the autodesk forum somewhere that they can't replicate this bug and are asking subscriptioners to submit a report so they can look into it...sounds like the ol' layer filter thingy has morphed!.. Yep, I get those too, sometimes hundreds of them. Real PIA! Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted February 2, 2008 Share Posted February 2, 2008 i have similar problems with the list where i get 1:10_xref_xref_xref and such and i remember reading on the autodesk forum somewhere that they can't replicate this bug and are asking subscriptioners to submit a report so they can look into it...sounds like the ol' layer filter thingy has morphed!.. It technically was not a bug. It was a bad design feature though. Prior to SP1 in AutoCAD, scale list entries were copied from each and every xref into the parent drawing. SP1 limits this to one xref deep. IF you don't have SP1 installed, get it. Quote Link to comment Share on other sites More sharing options...
Jadeous Posted April 13, 2009 Share Posted April 13, 2009 Everytime I try to view the Scale List I get this message!!! What is this?!! Quote Link to comment Share on other sites More sharing options...
