Sengna Posted March 24, 2017 Share Posted March 24, 2017 this might be simple to fix, when i selected object drag from top left to lower right, before it usually select as rectangle but now it shows something like LASSO, how do i fix this? i just want regular polygon select window. can i turn it off somewhere so it stops doing this. Thanks Quote Link to comment Share on other sites More sharing options...
Dana W Posted March 24, 2017 Share Posted March 24, 2017 Yes, you can turn it off, BUT now the window works on just clicking the corners. So, just click the corners. At times the Lasso (yes, it is called that) will come in handy. Just because it surprised you doesn't mean it's stupid. Have you ever had to select two or three times just to avoid one or two things? Well, now you don't have to, with a well dragged lasso you can go all over while avoiding certain objects. The lasso works with the usual left to right, or right to left behavior. It is in Options somewhere. Hit the F1 key. Then if you still want to turn it off, do so. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted March 25, 2017 Share Posted March 25, 2017 In OPTIONS you would find it on the left side of the SELECTION tab. Quote Link to comment Share on other sites More sharing options...
Sengna Posted March 27, 2017 Author Share Posted March 27, 2017 Yes, you can turn it off, BUT now the window works on just clicking the corners. So, just click the corners. At times the Lasso (yes, it is called that) will come in handy. Just because it surprised you doesn't mean it's stupid. Have you ever had to select two or three times just to avoid one or two things? Well, now you don't have to, with a well dragged lasso you can go all over while avoiding certain objects. The lasso works with the usual left to right, or right to left behavior. It is in Options somewhere. Hit the F1 key. Then if you still want to turn it off, do so. Thanks Dana W for your advice, yes, i have been through those issue before when i had to click so many times. It's good to know now that i know how to turn on and off. Thanks Quote Link to comment Share on other sites More sharing options...
Sengna Posted March 27, 2017 Author Share Posted March 27, 2017 In OPTIONS you would find it on the left side of the SELECTION tab. Thanks a lot Dadgad, i went into Options and selection, and unchecked the Lasso. how did they came up with the name LASSO? Quote Link to comment Share on other sites More sharing options...
Dana W Posted March 27, 2017 Share Posted March 27, 2017 how did they came up with the name LASSO?I don't know, maybe the same way you did, from watching the Rodeo on TV. Quote Link to comment Share on other sites More sharing options...
SunnyTurtle Posted March 27, 2017 Share Posted March 27, 2017 how did they came up with the name LASSO? I believe it is named after the photoshop tool lasso which work similarly. Also it is quite a handy tool once you get used to it. Quote Link to comment Share on other sites More sharing options...
Dana W Posted March 28, 2017 Share Posted March 28, 2017 I believe it is named after the photoshop tool lasso which work similarly. Also it is quite a handy tool once you get used to it.Yup, that is it. Quote Link to comment Share on other sites More sharing options...
