pmxcad Posted July 22, 2017 Share Posted July 22, 2017 Hello, can someone help me with this lisp. it is not working in AUtocad 2014. The lisp adds more visibilitys in a dynamic block. Thanks, PMXcad visibility-add-eng_1_6.lsp Quote Link to comment Share on other sites More sharing options...
Hippe013 Posted July 24, 2017 Share Posted July 24, 2017 What does it say when you load it? What appears to not be working for you? The lisp appears to be working (albeit confusing) in Civil 3d 2017. Quote Link to comment Share on other sites More sharing options...
pmxcad Posted July 25, 2017 Author Share Posted July 25, 2017 Hi Hippe013 I can only add the parameters (in existing dynamic block). The other commands give NIL after selecting. See the test block. The visibility states affect each other. I think because the selecting and deselecting functions are not working (nil). It may also be that I am doing the wrong actions or wrong order. Some web sites contain manuals, but they all have a different approach. Regards PmxCAD tst.dwg Quote Link to comment Share on other sites More sharing options...
Hippe013 Posted July 25, 2017 Share Posted July 25, 2017 Okay, Well, I have gone through the code and have found "where" it is going wrong. I have not found as to "why" it is going wrong. May I ask as to why you need to use this code? What does it offer that isn't already built into AutoCAD? In looking through this code I am finding that it's a fairly complicated maze of dxf codes. I heard that it is using dxf codes because what they want to do hasn't been exposed via COM. I would like to look into this. Despite the comments in the code it is still not quite clear as to what, how and why they are going about doing what they are intending to do. Quote Link to comment Share on other sites More sharing options...
Hippe013 Posted July 25, 2017 Share Posted July 25, 2017 This is a web page from the Author of the code. Very interesting read. http://www.private.peterlink.ru/poleshchuk/cad/2009/tainypod06e.htm Only to find that the Author has passed away. Here's to Andrey Viktorovich Lazebny. Quote Link to comment Share on other sites More sharing options...
pmxcad Posted August 5, 2017 Author Share Posted August 5, 2017 Certainly an interesting read. I have found another way to get what they want at work. PmxCAD Quote Link to comment Share on other sites More sharing options...
indomatt Posted January 25, 2018 Share Posted January 25, 2018 Although this code is quirky and has some bugs it is very useful. Using Autocad 2010, I have made a dynamic block with 16 different visibilities. It takes a while to learn how to use it but just keep playing with it and turning the dials. I have tried using it with Autocad 2016 with no luck. Quote Link to comment Share on other sites More sharing options...
