Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Go Back   AutoCAD Forums > AutoCAD > AutoCAD Beginners' Area
Reply
Thread Tools
Old 1st Feb 2003, 07:14 pm   #1
dangermouse
Posts: n/a
Default EXPLODING TEXT TO GEOMETRY
HI,
im now using autocad2002 and i would like to know how to expolode text so that it is basically converted in to lines and arcs (so i can incorporate it in to a milling prg ) .in autocad2000 there is a an express menu which has this item on it
thank you for your time
Old 1st Feb 2003, 09:02 pm   #2
superjari
Posts: n/a
You could type the EXPLODE command, or just use the explode button in the modify toolbar...
Old 2nd Feb 2003, 11:24 am   #3
robfowler
Posts: n/a
I think Express Tools was sold separate when it came to Acad 2002 but was free with 2000. Could you not migrate the Express Tools across to 2002?
For those without Express Tools there is another way to explode text and that is to WMF it out to a windows metafile and then insert the WMF file back into the drawing - now the text is exploded and can be extruded in 3D.
Rob.
Old 2nd Feb 2003, 12:01 pm   #4
robfowler
Posts: n/a
Forget the last part of my last post - I just tried it and it doesn't work. I'm sure I have used that method before and can't think what step I'm missing for the moment.
Sorry superjari, but you can't use the explode tool on mtext - it doesn't work.
Rob.
Old 2nd Feb 2003, 12:10 pm   #5
dangermouse
Posts: n/a
HI
thanks very much for your help,ill give it a go on monday at work and let you know how it goes.
always smiling dangermouse
Old 2nd Feb 2003, 12:56 pm   #6
superjari
Posts: n/a
Rob.
Yes,
I found out it doesn't work, I thought I once exploded text...
Sorry, my mistake...
Old 2nd Feb 2003, 08:40 pm   #7
CADTutor
Administrator
CADTutor's Avatar
Using: AutoCAD 2010
Rob.
That's a neat trick. Extrude won't work on lines and arcs but you can give them a thickness using the Properties Panel.
Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
AutoCAD Tutorials | How to add images to your posts | How to register successfully | Forum FAQ
CADTutor is offline   Reply With Quote
Old 2nd Feb 2003, 09:41 pm   #8
Mr T
Super Member
Mr T's Avatar
Using: AutoCAD 2007
Export as wmf then import and explode. They become 2d polylines. Only closed objects extrude but you can use a 2d polyline as a source object to create a TABSURF with the thickness ie back ways being the direction vector. TABSURF is similar to extrude but creates surfaces.
Nick
http://www.flickr.com/photos/80049703@N00/ http://mtbnick.fotopic.net/
http://s240.photobucket.com/albums/ff241/dyNick_Scots/
http://designgraphicsshowcase.blogspot.com/
High School Classroom - 21 AutoCAD 2007, Inventor 11, COREL Draw & Paint 11. Very Unreliable Network.
Home - AMD 2.1GHZ - 512Ram, 64 Video,
Laptop Inventor 7, Autocad 2004, Corel 11
Mr T is offline   Reply With Quote
Old 2nd Feb 2003, 09:51 pm   #9
dangermouse
Posts: n/a
Default EXPLODING TEXT AS GEOMETRY
HI,
What im actually doing is creating a drawing on 2002,and writing text onto it ,then this text is machined on the component ,so text needs to be geometry not jst text,for those that have privete messaged me asking .
Old 2nd Feb 2003, 11:07 pm   #10
gcp310
Super Moderator
gcp310's Avatar
Version: not applicable
Location: physicaly - Australia, mentaly - Another Planet
What we do in the signage industry is do the layout in coreldraw and export it out as .AI or .EPS
you have more control with the fonts,etc in corel.
We also use corel for the text and export it out as a .wmf>import it into cad as a .WMF>scale to suit>and then explode it.
we then can extrude it and render the text as 3D signage.
if you follow the .wmf way, you can then export it out as a .Stl file
which you can import into the cnc machine.
Hope this helps.
G
gcp310 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Why Donate?
RSS Feed for AutoCAD ForumsValid XHTML 1.0!Valid CSS!Creative Commons Licence
