I am currently working on a drawing where the z values of all lines are all different values. What command do i use to make these values 0. I don't want to do each line individually as this will take a lifetime. thanks.
select them all and make the Z value 0 in the properties palette
Or try using the FLATTEN command.
My bad - didn't spot that bit, i don't think it is.
well caught dave
