"ghost" layer (?) - mixed up properties (?)
hello! :)
i have something strange here.
i have a block with atts all in one layer "163_Utičnice_SR", as properties shows.
but if i go LAYWALK it shows me that atts are in layer "priključnice".
in block editor atts are in "163_Utičnice_SR".
in enhanced attribute editor, properties tab show that atts are in layer "Priključnice"!
i'm confused :huh:
Drawing3.dwg
That is strange! anyways don't know how this happened maybe when you where making the block you started out with the layer and changed later but the change wasn't properly excepted?
but when you
explode the block and then
select everything and create a block again it seems to be in the right layer then!
I see now!
when I open the file and do a laywalk it does what you say!
but when i insert the same block again without edeting anything that block is completely in the same layer! try it and do a laywalk and youl see!
Is there a command to update blocks or something cuz I thing you changed the layer after you inserted the block to modelspace!
Found it
cmd: attsync this udates your blocks attributes
yes i think that blocks were moved from layer to new one.
but i forgot to attsync it 3 or 4 months ago (i wasn't shure that i need it to attsync for layer changing).
thank you very much :)
no problem, I'm glad I could help out!
Click on properties int he EATTEDIT edit dialog and you can see which layer the text is set to.
