jabastin Posted July 4, 2009 Posted July 4, 2009 Dear Xperts! Is there any predifined scale command available in acad? 4 ex :I want 10 circles with the dimension of 30mm. without no copy and other commands ... hope understand and Help me Quote
Cad64 Posted July 4, 2009 Posted July 4, 2009 Watch your command line. After you create the first circle, with the diameter of 30mm, the next circle you draw will default to the previous diameter you entered. You don't have to enter the dimension every time. Why don't you want to use the Copy command or Array or Measure? It's faster than creating and placing each circle individually. Quote
Strix Posted July 4, 2009 Posted July 4, 2009 if all of your drawings will always contain several 30mm circles, it may be beneficial to create them as a block and create a keyboard shortcut to 'insert circle block' if that's not a suitable answer, some more explanation may be useful Quote
Lee Mac Posted July 5, 2009 Posted July 5, 2009 Quickest thing I could think of (defun c:qcir (/ tmp pt) (or def@rad (setq def@rad 1.)) (initget 6) (or (not (setq tmp (getdist (strcat "\nSpecify Radius of Circle <" (rtos def@rad) "> : ")))) (setq def@rad tmp)) (while (setq pt (getpoint "\nPick for Circle: ")) (entmake (list (cons 0 "CIRCLE") (cons 10 pt) (cons 40 def@rad)))) (princ)) Quote
Lee Mac Posted July 5, 2009 Posted July 5, 2009 Or, a dynamic Version! (defun c:mycircle (/ *error* inc msg gr lst i tmp) (vl-load-com) (defun *error* (msg) (redraw) (if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")) (princ (strcat "\n<< Error: " msg " >>")) (princ "\n*Cancel*")) (princ)) (or *Cir$Dia* (setq *Cir$Dia* 24.)) ; Initial Diameter (setq Inc 2.) ; Increment (princ (setq msg "\n<< Position Circle [+] or [-] to Change [D]iameter >>")) (while (progn (setq gr (grread t 15 0)) (redraw) (cond ((and (eq 5 (car gr)) (listp (cadr gr))) (setq lst nil i 0) (repeat 300 (setq lst (cons (polar (cadr gr) (* i (/ pi 150.)) (/ *Cir$Dia* 2.)) lst) i (1+ i))) (grvecs (append '(30) lst (cdr lst) (list (car lst)))) t) ; Keep in Loop ((eq 3 (car gr)) (entmakex (list (cons 0 "CIRCLE") (cons 10 (cadr gr)) (cons 40 (/ *Cir$Dia* 2.))))) ((eq 25 (car gr)) (princ "\n<< User Quit >>") nil) ; Exit Loop ((eq 2 (car gr)) ; Keyboard input (cond ((vl-position (cadr gr) '(61 43)) ; + (setq *Cir$Dia* (+ Inc *Cir$Dia*))) ((eq 45 (cadr gr)) ; - (if (> *Cir$Dia* Inc) (setq *Cir$Dia* (- *Cir$Dia* Inc)) (progn (princ "\n<< Minimum Circle Diameter Reached >>") (princ msg)))) ((vl-position (cadr gr) '(13 32)) (princ "\n<< User Quit >>") nil) ; Exit Loop ((vl-position (cadr gr) '(68 100)) ; D/d (initget 6) (if (setq tmp (getreal "\nSpecify Diameter: ")) (setq *Cir$Dia* tmp)))))))) (redraw) (princ)) Quote
