Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Go Back   AutoCAD Forums > AutoCAD > AutoCAD RSS Feeds
Reply
Thread Tools
Old 30th Oct 2009, 09:40 am   #1
Between the Lines
RSS Feed Posting Robot
Between the Lines's Avatar
Autodesk RSS Feed Project Cooper - Give it a New Name
Project Cooper is not the final name just a project name while the product is still in development phases. What do you think it should be called?  Help us give Project Cooper a permanent name!  Take this short, multiple-choice survey.  Should take less than 2 minutes, and we appreciate your input.
The SurveyMonkey survey link is live at:  Click Here to take survey
Have you tried Project Cooper with Win 7, or even XP?  If the answer is no then give it a try or mention it to someone that needs a super simple precision design tool. Be sure to email labs.cooper@autodesk.com with any comments you might have.
More...
Between the Lines - Autodesk blog by Shaan Hurley
Between the Lines is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Autodesk Project Cooper Between the Lines AutoCAD RSS Feeds 0 22nd Oct 2009 06:40 pm
Please give me a sample dwg from Acad M Raggi_Thor Mechanical 9 20th May 2009 03:27 pm
I Give Up!! studiorat AutoCAD 2D Drafting, Object Properties & the Interface 8 14th Feb 2008 04:28 pm
Pls give me a hint Alexandra AutoCAD General 11 26th May 2004 03:45 pm
Why Donate?
RSS Feed for AutoCAD ForumsValid XHTML 1.0!Valid CSS!Creative Commons Licence
