How to make Z=0
e.mounir
Hi all
i have new project , we make the shop drawing for it . The problem is all object in the file (line, circle, pline, rectangle ….etc. ) this in all files , I want make every thing (Z=0) I used AUTOCAD2009
Marry Christmas for all of you
  • Replies 42
  • Sbeth85
    11
  • ReMark
    10
  • tzframpton
    5
  • e.mounir
    5
Posted Images
It is not working
Can you give a little more info on what's happening instead of just "It is not working"? What exactly isn't working for you, the FLATTEN command? Or the link to the other routine that was posted?
Try this...
Command: move
Select objects: all
19 found
Select objects:
Specify base point or [Displacement] : 0,0,0
Specify second point or : 0,0,1e99
Command: move
Select objects: p
19 found
Select objects:
Specify second point or : 0,0,-1e99
Hey lpseifert I went searching through the help file regarding those fancy coordinate entries and I couldn't find exactly what you typed and what it meant. Can you give an explanation of what you typed, why, and how it effects the objects? I'm not understanding the "1e99" part.
Under Units, it's Scientific (exponential notation)
1e99 means 1 times 10 to the 99th power (very large number)
I think....
since these numbers are beyond acad's ability to process accurately, acad sees them as the largest number that can be processed. So the Z value + the displacement value of 1e99 essentially equals 1e99. It may have something to do with acad's precision only being 16 decimal spaces.
I would imagine that some one else has a better/more accurate explanation. I learned this trick from CAB, maybe he knows.
The FLATTEN command not working and also the link
I do what lpseifert said but every thing go away (not display) not found in the drawing
( Command: move
Select objects: all
19 found
Select objects:
Command: move
Select objects: p
19 found
Select objects:
  • 1 year later...
  • 3 years later...
arunz: The last viable post in this thread was three years ago. Why don't you go back to your most recent thread and continue the discussion there.
FYI - The last time the forum member you are trying to address was on CADTutor was December, 2012. It's almost 18 months later.
