I looking to find a way to create a list with AutoCAD versions currently installed on a particular station from the code of a stand-alone Visual Basic tool.
The code below will allow calling only the default version:
CreateObject("AutoCAD.Application")
What I’m trying is to generate a list with current installed version and allow the user to select via a pop-up list the version required for a processing.
Is there a solution to my issue? Thank you!
Regards,
Thank you!
Will have now to give this a try! Hope to come back with a solution.
