I have an old Release 14 drawing that will not open in 2009LT. It says "Corrupted Information, Needs Recovery". It opens fine in Rel14 though. I did a recovery in 2009LT and it still says "Needs Recovery". I also purged and did an audit in R14, but still no luck.
I couldn't find the .TMP file to do a rename. I even tried renaming the .BAK to DWG, and again no luck. Any thoughts?
Glenn
USA
DWG TrueView at AutoDesk website. It incorporates the full functionality of the old DWG TrueConvert program.
The poor drawing recovery may have something to do with text. R-14 and 2000 used text based upon the older True-Type standards, and some Win. 3.1 logic. You may need to load those older files in to your late model computer and give it another try. Not that you will see all of the recoveed text, but....
Wm.
ReMark, I have TruView2010. Is it just a typical conversion? Standard? Or to a lower version?The options are Standard, 2007 in place, 2004 in place and 2000 in folder.
Wm.
This is an isolated case. I have many older files without the problem. I've been using "ROMANS" for the past 10 years and I still use it in 2009LT. THe last thing I saw in the recovery was Fatal Error, and something Heap.
It might have been a reference to Heap memory.
Anybody here besides me that remember setting Stack and Heap values?
It's a Heap a sumptin alright.
ReMark, I did the DWG TruView 2010 convert to 2007 in place and it worked like a charm. Drawing is fine now. Thank you for the help again friend.
Glenn
You're entirely welcomed Glenn. Any time my friend.
