mateen Posted May 20, 2013 Posted May 20, 2013 hi, hope you all are fine.. today client send me one drawing which is on jpep file format so i want to convert that file into autocad so can you people refer me some go0d converting software.... Quote
MSasu Posted May 20, 2013 Posted May 20, 2013 I noticed that Adobe Illustrator seems to get good feedback. Quote
f700es Posted May 20, 2013 Posted May 20, 2013 (edited) Do a Google search on raster-to-vector conversion. Then prepare to be disappointed in the results. For simple bi-tonal images you can get good results but for anything technical it almost is easier to redraw. Edit: Typing fail Edited May 20, 2013 by f700es Quote
ReMark Posted May 20, 2013 Posted May 20, 2013 You can give scan2cad a try too. A couple of forum members have given it high praise. Might be interesting to see if it does indeed live up to the hype. You can test it and report back with your results. Or you can use AutoDesk's own "AutoCAD Raster Design" (30-day trial)... http://www.autodesk.com/products/autodesk-autocad-raster-design/free-trial Quote
