S.A.F. Posted August 17, 2006 Share Posted August 17, 2006 AutoCAD 2006 with service pack 1. No third party software loaded. So I used MVSETUP to rotate the view in one of my layouts yesterday, that worked fine, but when I returned to model space everything went haywire. First keyboard entry has gone south unless I start the command with the keyboard. EX: if I start the erase command and then select objects it works fine, if I select objects and press delete (or move, or match properties, or double click Mtext to edit etc, etc)NOTHING HAPPENS. say I select 3 lines, type M, spacebar, the three lines I just selected then deselect and I am prompted to select objects... If I double click a block to open block editor, nothing happens. If I right click a block, nothing happens. Its as if all commands cancel, but my command line shows no activity... I used to be able to right click an object, drag it somewhere and get a context menu :move, copy, cancel. Now nothing, cant move anything that way. This is universal, all my drawing files now behave like this. I have time sensitive right click turned on, don't work. I tried changing my profile back to AutoCAD default, no change. When I noticed the problem yesterday I undid all my actions back to before the MVSETUP command, problem still exists. Anyone have ANY idea Quote Link to comment Share on other sites More sharing options...
Cad64 Posted August 18, 2006 Share Posted August 18, 2006 It sounds like your PICKFIRST variable got changed somehow. Check to make sure it is set to 1. Quote Link to comment Share on other sites More sharing options...
S.A.F. Posted August 18, 2006 Author Share Posted August 18, 2006 You are an AutoCad GOD. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted August 19, 2006 Share Posted August 19, 2006 Glad I could help you out. Quote Link to comment Share on other sites More sharing options...
muleman Posted November 29, 2011 Share Posted November 29, 2011 It sounds like your PICKFIRST variable got changed somehow. Check to make sure it is set to 1. Thanks.... changing the pickfirst value in fact restores my right click menu ! Quote Link to comment Share on other sites More sharing options...
DannyHilltop Posted October 3, 2014 Share Posted October 3, 2014 It sounds like your PICKFIRST variable got changed somehow. Check to make sure it is set to 1. Thank you, I spent two hours this morning and very closely destroyed my PC, before finding your post. I changed this setting and it immediately started working. The question is, how did this get changed between yesterday and this morning. Crazy, but thanks again. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted October 6, 2014 Share Posted October 6, 2014 Usually it will get reset if you cancel, escape, etc. a command, third party program or LISP, etc. that doesn't have proper error handling. Quote Link to comment Share on other sites More sharing options...
