How to break a polyline in to the specific point?
tipu_sultane
I want to break a polyline into multiple polylines from one specific point to another.
A single polyline into multiples polylines.
Edited by tipu_sultane
I want to break a polyline in specific point.
Have you tried the BREAK command? Read the HELP on the various options, especially how to BREAK at a specific point.
Yes I used it but it deletes the portion of line. I just want to separate one line into multiples so that the total dimensions don't disturb.
No I just want to count the length of pipe on some network. Which are 1-way, 2-way, and 3-way.
You can find the two color line red and green in the attached image.
When I select the say green line as a result the selection of entire green line. I just want to break the line where there only one green line existing and find its length using area or list command.
Similarly to find the length of one line among with two parallel and multiply by two.
Any way If there is another easy method exist to find the length of lines separate on the basis of ways (1-way, 2way, and 3-way) then help me.
After selecting the object, the Command line gives you the option to specify the First and Second break point... just pick the same point for each.
Yes.
But I think this is easily possible by breaking the polylines into multiple from one specific point to another.
That makes easy to calculate length.
If you want to calc equal lengths - say 3 equal lengths.
Type - PDMODE change to 3.
Now type Divide and select the Pline3 for number of segments type 3 or whatever number
you want to divide the line into. This does not actually break the line but places a
node along the line at the specified break number - in this case 3
you could then use the break command and break the Pline to the node that is created when you divided the line.
Or you could skip PDMODE and the BREAK command and use the SubDivide lisp I mentioned previously. It will divide the line into equal segments whether you want 2, 20, 200 or whatever.
Here you go JerryG.
Credit goes to Kent1Cooper who uploaded the code on 05-11-2011 to the AutoDESK Community > AutoCAD Customization > Visual Lisp.... forum.
Have fun.
SubDivide.lsp
