mfkozlow Posted August 25, 2014 Share Posted August 25, 2014 Hello everyone! I tried the following script: (the OPEN_003 is a lisp that opens a drawing file that ends with "E003" & the GET_ATT is a lisp to retrieve a specific attribute from a block) FILEDIA 0 ZOOM E GET_ATT OPEN_003 ZOOM E GET_ATT QUIT When the above is ran, everything is done to the file that is opened initially. What I want is for the script beneath "OPEN_003" to run on the newly opened drawing. Is there a way to do this? If you have any other suggestions, let me know. Thanks. Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted August 25, 2014 Share Posted August 25, 2014 If we can see (c:get_att) and (c:open_003) than maybe we can find what's wrong... Quote Link to comment Share on other sites More sharing options...
mfkozlow Posted August 25, 2014 Author Share Posted August 25, 2014 Of course here it is: GET_ATT: (defun C:get_att() (if (setq ss (ssget "_F" '((7 2.5) (13.5 2.5)) '((0 . "INSERT")))) (progn (setq en (ssname ss 0)) (setq enlist(entget en)) ;- Get the DXF group codes (setq blkType(cdr(assoc 0 enlist))) ;- Save the type of entity (if (= blkType "INSERT") ;- If the entity type is an Insert entity (progn (if(= (cdr(assoc 66 enlist)) 1) ;- See if the attribute flag equals one (if so, attributes follow) (progn (setq en2(entnext en)) ;- Get the next sub-entity (setq enlist2(entget en2)) ;- Get the DXF group codes (setq enlist3(cdr(assoc 1 enlist2))) (while (/= (cdr(assoc 0 enlist2)) "SEQEND") ;- Start the while loop and keep ;- looping until SEQEND is found. (princ "\n ") ;-Print a new line (princ enlist2) ;- Print the attribute DXF group codes (setq en2(entnext en2)) ;- Get the next sub-entity (setq enlist2(entget en2)) ;- Get the DXF group codes ) ) ) ;- Close the if group code 66 = 1 statement ) ) ;- Close the if block type = "ATTRIB" statement ) ) ;- Close the if an Entity is selected statement ) OPEN_003: (defun c:open_003() (vl-load-com); [if needed] (vla-activate (vla-open (vla-get-documents (vlax-get-acad-object) ) (strcat (getvar 'dwgprefix) (substr (getvar 'dwgname) 1 5) "E003.dwg") ) ) ) The GET_ATT stores the attribute value in the "enlist3" variable. This is used later on. (Not in this script) Quote Link to comment Share on other sites More sharing options...
hmsilva Posted August 25, 2014 Share Posted August 25, 2014 Firstly "The GET_ATT stores the attribute value in the "enlist3" variable. This is used later on." you are calling the GET_ATT twice and store the att value to the same variable, only the last time will be stored.... Then you are quitting AutoCAD, the stoted value will be lost... Can you try to explain us what's your final goal? Henrique Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted August 25, 2014 Share Posted August 25, 2014 Not sure, but I would write your script without OPEN_003 function like this : FILEDIA 0 ZOOM E GET_ATT OPEN (strcat (getvar 'dwgprefix) (substr (getvar 'dwgname) 1 5) "E003.dwg") ZOOM E GET_ATT QUIT M.R. Quote Link to comment Share on other sites More sharing options...
mfkozlow Posted August 25, 2014 Author Share Posted August 25, 2014 What I want to do is the following: 1. Run batch file to start AutoCAD and open a drawing and run this script (I have the batch file working): FILEDIA 0 ZOOM E GET_ATT EXBOM OPEN_003 ZOOM E GET_ATT EXBOM FILEDIA 1 QUIT Where EXBOM: (defun C:EXBOM() (if (= enlist3 "1") (command "attext" "cdf" "g:/_001_auto_bom/TEMPLATES/SP1.txt" "SHT002") ) (if (= enlist3 "2") (command "attext" "cdf" "g:/_001_auto_bom/TEMPLATES/SP2.txt" "SHT002") ) (if (= enlist3 "3") (command "attext" "cdf" "g:/_001_auto_bom/TEMPLATES/SP3.txt" "SHT002") ) (if (= enlist3 "4") (command "attext" "cdf" "g:/_001_auto_bom/TEMPLATES/SP4.txt" "SHT002") ) (if (= enlist3 "5") (command "attext" "cdf" "g:/_001_auto_bom/TEMPLATES/SP5.txt" "SHT002") ) (if (= enlist3 "6") (command "attext" "cdf" "g:/_001_auto_bom/TEMPLATES/SP6.txt" "SHT002") ) (if (= enlist3 "7") (command "attext" "cdf" "g:/_001_auto_bom/TEMPLATES/SP7.txt" "SHT002") ) (if (= enlist3 "8") (command "attext" "cdf" "g:/_001_auto_bom/TEMPLATES/SP8.txt" "SHT002") ) (if (= enlist3 "9") (command "attext" "cdf" "g:/_001_auto_bom/TEMPLATES/SP9.txt" "SHT002") ) (if (= enlist3 "10") (command "attext" "cdf" "g:/_001_auto_bom/TEMPLATES/SP10.txt" "SHT002") ) (if (= enlist3 nil) (command "attext" "cdf" "g:/_001_auto_bom/TEMPLATES/SPNIL.txt" "SHT003") ) (if (not (= enlist3 nil)) (command "attext" "cdf" "g:/_001_auto_bom/TEMPLATES/QTY_SYSTEM.txt" "QTY") ) ) NOTE* I am aware that the variable is overwritten, but this does not matter. Once EXBOM is ran, the variable serves no purpose. It SHOULD get overwritten when it is ran on the new drawing (file ending in E003). 2. Once the script is ran the directory that holds the drawing files should contain the following text files (this is what I am after): QTY.txt SHT002.txt SHT003.txt 3. The final process my batch file executes is opening an Excel spreadsheet. This spreadsheet uses those text files to create a Bill of Materials. The problem I have with this process is that after the script calls the OPEN_003, the rest of the script is ran on the initial drawing...not the one that was just opened by the OPEN_003. Is there anyway to change this so that after the command OPEN_003 is ran the rest of the script is executed on the drawing that was just opened? Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted August 25, 2014 Share Posted August 25, 2014 Have you tried my suggestion : FILEDIA 0 ZOOM E GET_ATT EXBOM OPEN (strcat (getvar 'dwgprefix) (substr (getvar 'dwgname) 1 5) "E003.dwg") ZOOM E GET_ATT EXBOM FILEDIA 1 QUIT M.R. Quote Link to comment Share on other sites More sharing options...
mfkozlow Posted August 25, 2014 Author Share Posted August 25, 2014 Not sure, but I would write your script without OPEN_003 function like this : Code: FILEDIA 0 ZOOM E GET_ATT OPEN (strcat (getvar 'dwgprefix) (substr (getvar 'dwgname) 1 5) "E003.dwg") ZOOM E GET_ATT QUIT M.R. I just tried this and AutoCAD returned "Invalid File Name." All the files necessary are present and they are named correctly. Thanks for all the help everyone. Quote Link to comment Share on other sites More sharing options...
hmsilva Posted August 25, 2014 Share Posted August 25, 2014 Something like this perhaps. (defun c:demo ( / file fname ofile) (if (setq file (strcat (getvar 'dwgprefix) (substr (getvar 'dwgname) 1 5) "E003.dwg")) (progn (setq fname (strcat (getvar 'dwgprefix) "temp.scr") ofile (open fname "w")) (write-line "FILEDIA" ofile) (write-line "0" ofile) (write-line "ZOOM" ofile) (write-line "E" ofile) (write-line "GET_ATT" ofile) (write-line "EXBOM" ofile) (write-line "OPEN" ofile) (write-line (strcat (chr 34) file (chr 34)) ofile) (write-line "ZOOM" ofile) (write-line "E" ofile) (write-line "GET_ATT" ofile) (write-line "EXBOM" ofile) (write-line "FILEDIA" ofile) (write-line "1" ofile) (write-line "QUIT" ofile) (close ofile) (command "_.script" fname) ) (prompt "\nDwg E003, not found at the current directory!!!") ) (princ) ) HTH Henrique Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 25, 2014 Share Posted August 25, 2014 Hi Henrique Won't this be better than repeating the same function many times ? (mapcar '(lambda (s) (write-line s ofile)) (list "FILEDIA" "0" "ZOOM" "E" "GET_ATT" "EXBOM" "OPEN" (strcat (chr 34) file (chr 34)) "ZOOM" "E" "GET_ATT" "EXBOM" "FILEDIA" "1" "QUIT")) Quote Link to comment Share on other sites More sharing options...
hmsilva Posted August 25, 2014 Share Posted August 25, 2014 Hi Tharwat, defining an anonymous function, should be faster, and requires much less writing work... But depending on the OP understanding, I try to write the code in a comprehensive manner to the OP. Cheers Henrique Quote Link to comment Share on other sites More sharing options...
mfkozlow Posted August 25, 2014 Author Share Posted August 25, 2014 Thank you Henrique! This does exactly what I am looking for. Amazing...only a few hours and my problem is solved. Thanks everyone who contributed. Quote Link to comment Share on other sites More sharing options...
hmsilva Posted August 25, 2014 Share Posted August 25, 2014 You're welcome, mfkozlow Glad I could help! Henrique Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 25, 2014 Share Posted August 25, 2014 But depending on the OP understanding, I try to write the code in a comprehensive manner to the OP. Cheers Henrique Fair enough Cheers . Quote Link to comment Share on other sites More sharing options...
