Faouweb Posted September 29, 2014 Share Posted September 29, 2014 Hi, I have a 3d structure, and I want to know if there is a way to know the mass? What I do at the moment is, I find the Volume 'OBJECT' divide it by 10^9 and in the end times the density of the material. If its possible I want to learn how to do it with FORMULA in a TEXT FIELD. Thank you Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 30, 2014 Share Posted September 30, 2014 massprop check it out Quote Link to comment Share on other sites More sharing options...
Faouweb Posted September 30, 2014 Author Share Posted September 30, 2014 Thank you BIGAL, Where can I put the Density of the material? in my case steel 7840 kg/m3. Quote Link to comment Share on other sites More sharing options...
Faouweb Posted October 1, 2014 Author Share Posted October 1, 2014 Is it possible to add a new Variables in Calculator, as shown in the screen shot? Thank you. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted October 1, 2014 Share Posted October 1, 2014 Yes, you can add new Variables to Calculator. http://www.ellenfinkelstein.com/acadblog/create-a-custom-function-in-autocads-calculator/ Also for a LISP solution http://cadtips.cadalyst.com/mass-properties/tip-2258-calculate-weight or http://cadtips.cadalyst.com/mass-properties/determine-weights-3d-objects Quote Link to comment Share on other sites More sharing options...
Faouweb Posted October 1, 2014 Author Share Posted October 1, 2014 Thank you SLW210 Quote Link to comment Share on other sites More sharing options...
